Brief Description: Cabin Frame Roll Bar 30: Drill Frame to angles
After being convienced that the position of the frame on the angles is correct I clamped and drilled the two holes using the skin holes as guides.
I ensured the frame was flush with the skin forward edge. I ensured the line on the angles showed thru the holes like before. I clamped everything and drilled to 1/8.
This is going okay. It feels a little stressful because a screw up could cost a lot of rework or worse.
