Brief Description: Fwd Fuselage - Landing Gear Mount Fit 5
Turns out fitting the mount was the easy part. Making it installable thru the forward bottom skin is tough. First I started by making the mounts fit thru the hole with the skin just laying on the bench. I had to widen the holes beyond the dimensions of the paper template.
