Brief Description: F-707, 708 Bulkheads - Static Line Attach Holes
The 708 bulkhead has 8x 1/8 holes to attach the static line. I measured and drilled those. These will carry the static line from starboard to port and then forward. If you do these measure each side separately. Don't jump the dimension across the top or the holes will be to high on the other side.
