Brief Description: F-704 Bulkhead - Fab F-633 Control Col Mounts 3
I clamped the mount in place and squared it using my speed square. I drilled the lower hole. No problem. Then I taped shut the bearing cleaned and primed the control column mounts. I installed them on the 704 bulkhead, but I'm not torquing the bolts at this point.
