Brief Description: Ribs - Right Wing Ribs & Spars Laid Up
I clecoed the right wing and match drilled the holes. I deburred, dimpled, and primed the ribs. I did not prime the nose ribs. I riveted the ribs to the spar and then put the frame on the wing fixture. This process was a repeat of the left wing. I did get one bad rivet, but word from Van's was, "leave it alone. It is fine." I made the fixture so all for points of the frame can be clamped. So next stop, the skins.
