RV-7A Construction Log
RV-7A
Canopy Frame 10
You can pull the hinges away from the frame for deburring and priming.
There are several steps of drilling, dis-assemble for debur, re-assemble and drill something else. Seems like it went like this:
1) Drill fwd skin holes
2) Drill aft skin holes
debur
3) Drill splice plate
debur
4) Drill hinge top holes and to frame spar
debur
5) Enlarge splice plate to 1/8.
Pull apart for deburring
Hinges and splice plate drilled
Debur and re-assemble again
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
