RV-7A Construction Log
RV-7A
Canopy Frame 9
While the deburred frame was in place I drilled the holes in the hinges. I match drilled using the skin for location.
After dis-assembling, deburring and re-assembling I clecoed and drilled the 1/8 holes thru the hinges into the frame spar.
Drilled hinges
Drilled hinges from top
Drilling hinge to frame
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
