RV-7A Construction Log
RV-7A
Canopy Install: Canopy Release 4
The release hinge block gets a bellcrank installed.
I enlarged the big hole a little to make the bellcrank turn easier. I did this with a 1/2 drill bit and sandpaper.
I matched the clocking of the bellcrank with the lever arm against the drawing and drilled the bolt hole.
Then I located it on the sub-panel and marked the position where the bolt hit the sub=panel and made an oval cut out.
Lever clocked with bellcrank
Block and bellcrank
Position & make oval cut out
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
