RV-7A Construction Log
RV-7A
Canopy Install: Canopy Release 5
Next the release hinge block gets drilled to the sub-panel and platenuts installed.
I clamped the block in position and drilled the two #12 holes.
Then to locate platenuts, I put a #8 screw thru the platenut backwards, and clecoed it in place for drilling the rivet holes.
Then to rivet it, I bolted the platenut in place and used flush platenut rivets which are pulled rivets.
Screw helps locate platenut
Drill rivet holes
Pulled rivets for platenuts
RV-7A Home
1764
53
Cert & Flying
62
75
Cowl
48
181
148
238
Fuselage After Flip
385
237
Gear
78
57
Shop
Training Projects
437
