Installed the propeller spinner cone; easy stuff. Just have to take the crush plate off, add the spinner base underneath, put the bolts back in and screw the cone on the base, being sure to line it up with the mark from the factory. Blue Loctite on all threads. I did have to file the spinner down about a 1/4" when fitting the cowling.
Also did figure out that the Viking engine spins the other way, so I did flip the prop blades around after these pictures.
