Sid & Houston Mayeux Project
Date:  10-29-2014
Number of Hours:  2.50
Manual Reference:  Wheel Pants
Brief Description:  Installing Wheel Pants, part 1
On to the wheel pants!
I started by selecting which two front/back halves seemed to fit together best, which ain't saying much because they don't fit well at all. However, two pairs did seem to go together better leaving less sanding/fit work. I assigned them their "left"/"right" labels and started marking, trimming, and sanding until the fit was great.
I then marked drill points on the flanges, mated them, and drilled #30 pilot holes through the flanges so that they'll go together.
Aligning the front/back tire hole edges
Sanding down to fit the two halves
Sanded, fitted, cleco'd and drilled
