Sid & Houston Mayeux Project
Date:  3-20-2015
Number of Hours:  3.00
Manual Reference:  Flap Sensor
Brief Description:  Rewiring the flap position sensor
As I was removing the panels from the baggage compartment of weighing the aircraft, I accidentally pulled the flap position sensor's wires out of the cheap little Molex connector I had used to attach them. I hate Molex, so I ramped up to a 4-pin round connector. I happened to have one designed as a bulkhead pass-through.
This works much better, and I think will do a better job of securing the wiring. I wrapped both sides with spiral nylon wrap to protect the wiring. I think I'll use zip ties on each end to give it added stability.l
Bulkhead connector, forward side...
...and aft side
...and aft side
