Sid & Houston Mayeux Project
Date:  11-26-2014
Number of Hours:  2.50
Manual Reference:  Wing Installation
Brief Description:  Torquing the wing bolts
I installed the smaller diameter wing bolts, then torqued all bolts down to spec. I could torque down the upper nuts because they were accessible, but had to put the torque wrench on the bolt end of the lower bolts.
Installing the narrow-diamater tight-tolerance wing bolts
Wing bolts torqued
Wing bolts torqued
Wing bolt nuts torqued
