Sid & Houston Mayeux Project
Date:  11-6-2014
Number of Hours:  0.50
Manual Reference:  Nose Fairing
Brief Description:  Nose Fairing, part 3
I used my laser leveler to locate holes for my tow bar attach tubes. First I centered the laser's red horizontal and vertical lines on the attachment lug, then installed the fairing to the nose gear. I the marked a drill-point where the two laser lines intersected (right on top of the lug). I did the same on the other side. I then removed the fairing and drilled a 1 inch hole at the marks.
Image 3 shows me heating shrink tube on the ends of the tow bar tubes. This should protect the fairing when connect the tow bar to the nose gear.
Nose Cap installed
Nose Cap installed
Tow bar holes drilled
Shrink-tubing the tow bar
