Sid & Houston Mayeux Project
Date:  11-6-2014
Manual Reference:  Nose Fairing
Brief Description:  Nose Fairing, part 2
With the nose fairing finally trimmed and installed, I fitted and riveted the piano hinge to the nose strut fairing. This strut fairing is the piece that came with my Anti-Splat leg brace.
Image 3 shows the metal shims I have that are exactly 1/8" thick, which is the required space required between the wheel and leg fairings. I kept shaving the leg fairing's bottom surface until I had a nice transition between the two with exactly 1/8" space.
Nose strut fairing piano hinge
Bottom aligned
Bottom aligned
1/8" spacing
