Sid & Houston Mayeux Project
Date:  6-29-2014
Manual Reference:  Cowling
Brief Description:  Final cowling fit
With the inside surface epoxy cured, I reassembled the cowlings for final fit check. Image 2 shows a little overlap between the top and bottom skins: This showed up on both sides. I just sanded both sides down with a long straight block and 80 grit, so now they look perfectly flush.
Top and bottom cowlings in place
Front cheek overlap
Front cheek overlap
