Brief Description: Center floor cover angle channel, part 2
With the channel hole cut into the center floor cover and access plate, I cleaned up the edges, drilled and installed K1000-8 plate nuts for the channel cover, then painted. I installed the center floor cover and ran the wires and fuel line for zero stacking and interference (see image 2). I then installed the access plate to ensure there was no edge interference in the new hole at the 90-degree turn (see image 3).
