Sid & Houston Mayeux Project
Date:  5-27-2014
Manual Reference:  Center Floor Cover
Brief Description:  Center floor cover angle channel, part 1
As you recall from 22 May, I had not given myself enough slack to let the wiring round the 90-degree turn at the junction between the cockpit floor and the firewall. Instead of trying to fish more slack out the wire runs (and introduce more stress), I decided to just create more room for the wiring.
I fabricated a 45-degree channel from scrap aluminum. This 45-degree channel consists of two sides each cut as a right triangle with 3" legs and a 4.25" hypotnuse. Yes, this means I got to actually apply Pathagoream's Theorum (although I guess I could have just used my angle to draw a right triangle with 3" legs, then connect the ends, but that would be too easy...sheesh!).
I riveted these together with AN426-AD3 flush rivets, and added two end flanges with screw holes.
I assembled the center cabin cover to the F-982E access cover, then marked the cut lines for my newly fabricated angle channel (image 3).
More to come...
The angle channel
The angle channel
Marked for cutting
Marked for cutting
