Brief Description: Oil/Air Seperator installation part 1
I installed AntiSplat's oil/air seperator, which removes oil mist from the engine crankcase. Normally, Lycoming engines just have a breather tube that carries this misted oil from the crankcase down and vents it overboard by the exhaust pipes. However, this normally results in a lot of oil residue on the aircraft's belly. This system should collect that oil, return much of it to the crankcase, and vent the rest directly into one of the exhaust pipes where the oil is burned off. Clean Belly!!
