Brief Description: Installing the Throttle and Mixture cables
I installed the throttle and mixture cables, running them from the cockpit throttle quadrant forward through the firewall to their mounting brackets on the engine bottom and left side. I finished assembly on the throttle/mixture linkages at the fuel injector, then attached the cables. I adjusted these connections with the cable knobs pushed in, then backed off not quite 1/8". I get full travel from stop to stop.
