Sid & Houston Mayeux Project
Date:  1-22-2014
Number of Hours:  3.00
Manual Reference:  Canopy Latch
Brief Description:  New canopy latch, part 1
JD Air Parts offers some really nice items for the RV-7 series. I bought their canopy latch system, along with their fuel vent and fuel drain covers.
Their canopy latch system is a huge improvement over the flimsy latch that comes with the stock RV-7A kit. Looks better, much stouter.
I removed the old latch from my aircraft, and drilled out the two rows of #3 rivets that held those angle mounts to the aircraft side skin. Then, following the JD plans, I cut two lengths of 0.063" x 3/4" x 3/4" angle for the mounts.
I used the top row of existing rivet holes on the fuselage skin to match-drill the top angle mount (images 1 and 3). I then measured/drilled bolt holes through the angle for the two latch pieces, using the pieces as guides per the directions (image 2).
Fabricating the top angle mount
Latch system, fit test
Drilling the bolt holes on the top angle mount
