Sid & Houston Mayeux Project
Date:  8-4-2012
Manual Reference:  Heat Vent Valve 2
Brief Description:  Installing the heat vent valve part 2
Everything aligned! Final-drill to #12, debur (a lot), install platenuts. Recheck fit. All good...I gooped red RTV onto the vent valve assembly's face and mounted the assembly to the firewall with bolts into the rivets. I was careful to NOT get RTV into the vent valve's moving parts.
After that, Kelli helped me rivet the firewall center recess into place. I used 3M Fire Barrier 2000+ to fill the gaps.
Heat vent valve in place
Heat vent valve in place (forward view)
Firewall access in place, awaiting Fire Barrier
