Sid & Houston Mayeux Project
Date:  7-18-2012
Number of Hours:  3.00
Manual Reference:  Wheel brake lines
Brief Description:  Fabricating/installing the wheel brake lines
I fabricated the wheel brake lines from 1/4 inch aluminum tube. Following the Van's design, I ran the lines down the back of the strut, then bent a coil around the strut and into the cylinder.
Images 2 and 3 show white zip-ties holding the line to the gear leg. I replaced those with black UV-resistant zip ties. I also ran those lines inside a length of clear nylon tubing to give them strength and stress relief.
Brake line coil into the left cylinder
Right main gear
Right main gear
Left main gear
Left main gear
