Sid & Houston Mayeux Project
Date:  4-7-2012
Number of Hours:  3.00
Manual Reference:  Sub-Panel
Brief Description:  Pre-drilling avionics mounts, building up panel su
I moved on to finishing the forward upper fuselage. I removed the forward canopy frame, then riveted the structure in place. I picked final places for the avionics modules and drilled their attachment holes: 2x SkyView back-up batteries, SkyView transponder and engine monitor module, and the PS Electronics VHF transmitter module. All avionics are back in their boxes for storage--shouldn't come back out until the fuselage is just about finished.
As you may recall, I had removed the rear half of the two subpanel-to-panel structural ribs: I cut them flush where they emerge aft of the sub-panel. I then riveted an AA6-.063x3/4x3/4 rib to the ribs' forward ends so that I could rivet in new places to the rear face of the subpanel. Placement was guided by the holes in my new instrument panel. Those holes were placed at the Vans-spec height and spacing, but displaced inward to accomodate the SkyView screens. The ribs aligned perfectly with the panel's screw holes. Mounted in place, I marked rivet placement spots on the subpanel, matchdrilled using pre-drilled pilot holes on the new angle, then riveted in place.
Image 3 shows the final fit--perfect! That panel is now going into protective custody, and I'll use the stock Vans panel blank for canopy frame fitting.
Avionics and Rib placements
Subpanel and panel ribs riveted
Panel fits like a glove!
