Brief Description: Ran the static plumbing and shoulder harness cable
I ran the static lines from the ports forward through adel clamps to elbows to the top of the fuselage. There, they join at a T and will run forward to the Dynon Skyview ADAHRS (main plus spare).
I'm using the FlySafe pitot/static/AOA plumbing kit...slick!!
The shoulder harness cable (image 2) looks like it runs upward, but you can see the rest of the cable coiled up in the plastic bag. It'll actually run forward parallel to that longeron. Thus, there's no conflict between the cable and the static tube.
Plumbing runs up to center T
Static lines deconflicted from shoulder harness cable
