Brief Description: Riveting the anti-collision mount stiffiners to th
2-man project! Houston and I riveted the stiffiners into the top/bottom fuselage mount points for the anti-collision beacons. We used the back-rivet method: I took the rivet gun into the fuselage, and Houston inserted the rivets in place and used our Tungsten bucking bar as the flush surface. These turned out beautifully flush on the fuseage skin surface, with no proud rivets.
I'll mount the beacons later after I've completed the wiring.
