Sid & Houston Mayeux Project
Date:  1-1-2012
Manual Reference:  Canopy Frame
Brief Description:  Canopy hinge mounting blocks
The canopy's forward frame mounts to the forward cockpit sub-panel through two hinge brackets. These brackets are sandwiched between two nylon blocks and the ribs mounted to the sub-panel's central and outer assemblies.
Started by fabricating and match-drilling the hinge mounting blocks
Drilling the canopy hinge blocks
Drilling the hinge block assembly spacer
