Sid & Houston Mayeux Project
RV-7A
Elev. push rod
Elevator push rod (rear half)
Built the rear push rod for the elevator. Drilled the holes with my drill press, deburred, then primed the inside of the tube rod to prevent internal corrosion of the aluminum. Pop-riveted the end caps on.
Drilled the rivet holes
Pop-riveting the rod caps to the rod
Rod caps are on, ready for the bearing bolt
RV-7A Home
1549
Cockpit
49
135
279
92
Flight Controls
354
192
Wrap Saga A - Dream
Wrap Saga B -- Victo
Wrap Saga C -- Petit
Wrap Saga D -- Fligh
Wrap Saga E -- Emerg
Wrap Saga F -- Home
