Sid & Houston Mayeux Project
Date:  5-5-2011
Manual Reference:  Roll Servo
Brief Description:  Autopilot roll servo, right wing #1
Installed Dynon's autopilot roll channel servo. This will link via data cable to the Dynon SkyView EFIS I plan to install.
Dynon actually enclosed a link tube many inches longer than the 3-inch requirement. We measured and cut the tube down to 3 inches, then tapped the unthreaded end. Houston did a great job tapping the end of the link tube that connects the servo arm with the aileron bell crank.
Installing the servo
Houston taps the link tube
Link tube (ends not yet aligned)
