Sid & Houston Mayeux Project
Date:  5-7-2011
Number of Hours:  1.00
Manual Reference:  Stall Warner wires
Brief Description:  Running Stall Warner wiring
In the left wing, I ran the stall warner wiring through a slit in the conduit, then on down the wing with the rest of the wiring. I drilled a small hole (#30 drill) in the wing rib just inboard of the wire's passage through the main spar, and zip-tied the wire there to keep it clear of the aileron bellcrank/push tube movement.
Slitting the conduit
Pulling the wiring through
