Sid & Houston Mayeux Project
Date:  3-15-2011
Manual Reference:  Stall Warning
Brief Description:  Began installing the stall warning system in left
The left QB wing has an access hole precut for the stall warning system...just needed to line up parts, match-drill, then debur and dimple for the rivets and screw plates. After this I primed the parts with MarHyde rattlecan primer.
Match-drilling the access plate stiffiner
Access plate and stiffiner matchdrilled
All holes dimpled
All holes dimpled
