Brief Description: Assembling the fuel feed hardware to the tank acce
The fuel feed tube mounts to an elbow in a turn-stop bracket on the inside of the tank access plate. It takes some trial/error to make sure the tube and elbow are properly aligned, and you have to align them while mounted in the bracket. Once it's all aligned, you then rivet the bracket to the plate. Slow and easy.
The big hole in the plate's center is where the fuel level sender mounts.
