I fired up a batch of VE resin and layed up the left side forward shell attach points. I previously did this and had a eating feeling in my gut saying something was wrong which I did not listen to until later. What was wrong was that I only layed up 1 layer of glass on each bracket instead of the 4 necessary. Well I fixed that tonight. I also layed up the glass shim in the tailcone to adjust the HS stab forward bracket. I took the rest of my time and cleaned up the intershearweb and cut the center attach plate. I also marked a center line on the plate.
