Schroeders Sportsman
Date:  8-25-2019
Brief Description:  Priming for delta wings
I did a lot of fuselage cleaning and got my shearweb sorted in the tail. I have a lot of work to get that installed as the fit is not longer what it was when i built it. So a litte cut and fit is in order. I also masked out and primed the wing skin under the delta wing I need to install for the ailerons.
