Schroeders Sportsman
Date:  1-23-2016
Number of Hours:  1.70
Brief Description:  Firewall work
I installed the oil pressure gage and the current limiter. I also grooved the left rear of the baffeling to allow for the sensor wire pass through. It was installed for the tach reading to the electroinc ignition and hahad a D-sub setup on the other end. So I couldn't simply pass it through a drilled hole.
