Schroeders Sportsman
Date:  11-7-2010
Number of Hours:  1.60
Manual Reference:  p139
Brief Description:  Forward Attach Tabs
I cleaned up the glass I layed up on the forward fuselage attach tabs and drilled for rivets. I broke out the pull rivet gun and installed the rivets. Looking good. I also cleaned up the glass shim for the forward HS stab attach bracket. I drilled the holes and installed the bracket. Next time we'll see if that did the trick.
