Jims Web Site
Date:  3-10-2010
Number of Hours:  1.00
Manual Reference:  unnumbered drawing
Brief Description:  Installed rudder pedal - nosewheel pushrods
1. Located pushrods and bearings.
2. Located closeouts.
3. Established rivet hole pattern on closeouts, and drilled with #40 bit.
4. Taped closeouts on firewall.
5. Backdrilled with #40 bit and clecoed.
6. Opened holes with #30 bit for A4 rivets, and clecoed.
7. Removed, deburred, cleaned, and primed with zinc chromate primer.
8. Clecoed back in place.
9. Ran pushrods through closeouts, and connected to rudder pedals and nose gear.
10. Snugged, but did not cotter or tighten, mounting nuts. Rods may require removal later.
11. Riveted closeouts in place with A4 rivets.
Installed pushrod closeouts
pushrods connected to rudder pedals
pushrods connected to nose grear
