Brief Description: Removed remaining caps from center spar
1. Punched rivet heads with center punch. 2. Drilled through center of heads with #40 bit. 3. Opened holes with #30 bit. 4. Removed shop heads with chisel. 5. Punched out core with drift, removing manufactured heads as necessary with chisel. 6. Marked parts for later reassembly.
