Brief Description: Removed stbd wing nose skins and fuel tank
1. Drilled out upper skin rivets with #20 bit, except at tip, where #30 was used. 2. Removed fuel tank. 3. Drilled out lower skin rivets with #20, bit, except at tip, where #30 was used. 4. Secured skin to ribs with two clecoes per rib, while lower rivets were removed. 5. Removed clecoes and skin. 6. Stored skin for later use.
