Jims Web Site
Date: 1-22-2011
Number of Hours: 2.00
Manual Reference: 6ZU1
Brief Description: Prepared inboard 6ZU1-6 for installation
1. Drilled out top vertical rivets on wing ribs 8,9, and 10. 2. Punched out rivets. 3. Clamped outboard port channel angle 6ZU1-6 in place, after trimming end. 4. Back drilled through existing mounting holes at wing ribs 8, 9 and 10, with #30 bit for rib 10, and #20 bit for 8 and 9. 5. Back drilled #30 holes through 6ZU1-8. 6. Clecoed and clamped in place. 7. Back drilled top rivet holes through rear spar and 6ZU1-6 outboard. 8. Removed clecoes, and created #40 pilot holes in vertical edge of 6ZU1-6 outboard, using #40 bit. 9. Clecoed 6ZU1-6 back in place, and back drilled vertical holes with #20 bit, clecoing alternate holes.
Back drilled existing top rivet holes
Created vertical pilot holes in inboard channel doubler
Back drilled rivet holes in 6ZU1-6
