Brief Description: Reworked battery power installation
The external power receptacle fit not appear to make a water-tight seal with the outside of the aircraft, so it was decided to add a gasket under the external power connector.
1. Traced power connector onto gasket material. 2. Cut gasket, and fit checked. 3. Re-installed external power connector.
