Brief Description: Updated Light Speed Control panel
When I tried to add the shielded leads to the control panel, I started running into problems. Lightspeed wanted everything shielded. There was no way this was going to work. I decided to build a shielded box around the control panel, so the leads needed to be shielded only when entering and leaving the box.
1) Fabricated enclosure 2) Installed terminal board assignments pin 1,2,3 shield grounds pin 4 center conductor out to bottom Lightspeed unit pin 5 center conductor out to top Lightspeed unit pin 6 alternator fail pin 7 power to bottom circuit breaker pin 8 power to top circuit breaker pin 9 bottom fail warning light pin 10 top fail warning light. 3) I wired as much as I could on the workbench, befo0re moving the unit to the aircraft.
