Brief Description: Moved stobe control to port side of aircraft
As I began to look at a disconnect for the wing strobes, it became evident the strobe control box needed to be moved to the port side, where the terminal board for similar items was located.
1. Drilled out rivets holding strobe control box in place. 2. Removed box, and disconnected power/ground leads. 3. Pulled rivets in vacated holes. 4. Re-routed power and ground to the termin board on the port side of the aircraft. 5. Positioned strobe box near terminal strip, and drilled mounting holes. 6. Deburred holes, and pulled rivets to secure box. 7. Connected box to terminal strip for power.
