Jims Web Site
Date: 10-29-2009
Number of Hours: 1.60
Manual Reference: 6B23
Brief Description: Cut fairleads 6B23-2, -3, and -4
1. Marked fairlead material for fairleads 6B23-2, 6B23-3, and 6B23-4. 2. Cut indivudal fairleads on bandsaw, and sanded edges smooth with belt sander. 3. Trimmed any "fuzz" with flat file. 4. Punched rivet locations. 5. Pilot drilled rivet holes with #40 bit. 6. Positioned and clamped 6B23-2 on rear channel 6B5-2. 7. Back drilled rivet holes with #40 bit, and clecoed in place. 8. Positioned and masking taped 6B23-4 on rear channel 6B5-2. 9. Back drilled one hole with #40 bit, clecoed, and drilled, then clecoed a second. 10. Back drilled remaining holes with #40 bit. 11. Opened all holes with #20 bit for A5 rivets. 12. Cleaned and deburred holes on fair leads and rear channel. 13. Primed back side of fairleads with zinc chromate primer. 14. After primer had cured, reclecoed 6B23-2 and 6B23-4 to rear channel. 15. Riveted with A5 rivets.
Fairleads cut and drilled
Primed and clecoed in place
Installed
