Jims Web Site
Date: 10-29-2009
Number of Hours: 2.50
Manual Reference: 6B8,6B9
Brief Description: Riveted rudder pedals and brakes in place.
1. Positioned lateral pedal bearings 6B9-5, and clecoed in place. 2. Placed rudder pedals 6B9-1 in position through pedal bearings 6B9-5. 3. Slipped lower central pedal bearing, 6B9-4, into position, under rudder pedals. 4. Placed upper central pedal bearing atop rudder pedals. 5. Slipped 3 AN3-16A bolts and washers through upper pedal bearing, securing rudder pedal position. 6. Individually opened mounting hoes in lateral pedal bearings to 3/16", and secured each with an AN3-5A bolt, two washers, and locknut. 7. Secured central pedal bearing with washers and notnuts. 8. Positioned brake cylinder supports 6B9-6, and clecoed in place. 9. Riveted brake cylinder supports with A5 rivets. 10. Installed brake cylinders MC-5 with AN3-11 bolts, washers, and castelated nuts. 11. Inserted cotter pins in AN3-11 bolts, and secured. 12. Connected brake cylinders to brake pedals 6B9-3 with AN3-7 bolts, washers, and castelated nut. 13. Inserted cotter pins in AN3-7 bolts, and secured.
Rudder pedals in position
Rudder pedals bolted in place
Brake cylinders riveted in place.
