Brief Description: Set rudder deflection & tensioned cables
1. I moved tghe cable splice on the port side to allow correct setting of rudder throw. I then tensioned the cables for 40 pounds, and saftied the turnbuckles. Once again, Zenith's method of angular measurment leaves a lot to be desired.
