1) Ordered engraved data plate. 2) Filled engraving with red paint, save as aircraft. 3) Removed excess with scotch-brite like adhesive. 4) Sprayed clear coat on plate. 5) Taped plate in place on aircraft. 6) Drilled first hole & clecoed. 7) Drilled and clecoed remaining holes. 8) Replaced clecoes with A4 rivets & pulled.
