1) Cut cardboard patterns for covering material on console sides and sidewall of aircraft. The console pattern may only serve to cut the material; the sidewall pattern may be the material glued to it as a stiffner. 2) Attached forward console cover to aft console cover with 4 ea MS35206 screws, washers, and locknuts. 3) Cut foam cushion for top of center console.
