1. Reporisitionef throttle idle positioon, and tested. Test shows idle now OK, but full throttle not high enough. I plan to reposition the throgle linkage on the tghrottle arm.
2. Removed primer from inside cockpit, and removed fuel lie to/from. I reused the primer seal on the CDI manifold pressure line.
3. Connected the hour meter to aircraft power, so engine running time will now be logged.
