1) Removed vacuum pump close oup. Edges had burrs, which probably kept closeout from sealing correctly. I removed the burrs on a grinder, and cut a new gasket.
2. Removed primer feed to carby, and installed an adapter to feed manifold pressure to the CDIs. The CDI end is not yet installed.
3. Removed feed to primer from fuel manifold. Plugged manifold.
